Keyless Access, includes keyless ignition which is engaged with push button start, and 2 remote transmitters which enable passive entry on both front doors and trunk, and remote start capability
Lighting, illuminated entry and exit, includes courtesy lamps and entrance lamps in base of door and under IP
Tail lamps, LED illumination
Wheels, 4 17" x 7.5" (43.2 cm x 19.1 cm) cast aluminum painted, 7-spoke
1 - Upgradeable to (N93) Wheels, 4 - 17" x 7.5" (43.2 cm x 19.1 cm) aluminum polished.
Driver Shift Control
Engine, 3.6L V6 VVT (260 HP [193.9 kW] @ 6500 rpm, 252 lb.-ft. [340.2 N-m] @ 2800 rpm)
1 - Requires (M82) Transmission, auto, 5-speed, HMD, 5L40-E
Engine, 4.6L Northstar V8 VVT, SFI variable valve timing, Northstar (320 HP [238.6 kW] @ 6400 rpm, 315 lb.-ft. [425.3 N-m] @ 4400 rpm)
1 - Requires (M22) Transmission, auto 5-speed, HMD, 5L50-E for RWD or (MV3) Transmission, auto, 5-speed, HMD, 5L50-E PTU for AWD
Sound System, ETR AM/FM Studio Surround Sound Bose 5.1 with in-dash 6 disc DVD changer, DVD-based Advanced Navigation, includes Radio Data System, seek-and-scan, digital clock, automatic volume compensation, TheftLock, weather band, digital signal processing and 15 speakers, rear passenger A/V jacks
Steering wheel, leather-wrapped rim, heated
Headlamps, Xenon, high-intensity discharge, windshield wiper activated, includes flash-to-pass and headlamp washers
Spoiler, decklid
Wheels, 4 - 18" x 8" (45.6 cm x 20.3 cm) cast aluminum polished, 9-spoke faceted
Brakes, 17", performance
Suspension, 4-wheel independent with Magnetic Ride Control
(i'm not listing ALL options, just the most upscale)
Choice between RWD and AWD with the V8 :woot2: :bounce:
