1 - 1 of 1 Posts
This is my first time on this site so hopefully I have done this right!...
I replaced my iginition cylinder believing this was the reason for my car not starting. Unfortunately that was an improper assumption. So, off to the dealer I have the car towed and they replace the ignition switch. When I got the car back the original factory settings were not in place. Based on your experience I am sure you are aware that when you press the remote one time the driver side unlocks, pressed twice all doors unlock, when the car is started all doors lock, when put in park all doors unlock, lights go on and off inside and out automatically etc.
So, I take to my manual to reprogram these areas and there are basically 4 different settings that you can eventuate by placing your ignition key in the on position and going through certain motions described therein. Well, I started the process and walked away from the car. I got distracted and left the key in the car in the "on" position over night. When I went back to the car I got nothing. No security light, no headlights, no dash lights, remote would not work for anything. I was in hopes that it was the battery and that charging it and/or disconnecting it would make a difference. No such luck. There might as well be no battery. I have never had a car that so clearly acts as though it is "Dead as a doornail!"
It is very hard for me to believe that a simple (?) mistake like this can merit hundreds of dollars to remedy! I have been searching high and low for information about how to correct this. Surely there is a home remedy since there has obviously been no theft efforts. You would think this might actually come with a warning of sorts if this is the way it works! Please tell me you can help!? I can also be reached at [email protected].
Thank you,
Jim
1 - 1 of 1 Posts
