Hello,
This one has me stumped. I have '96 Chevy 1500 5.7L truck. Its been running strong and going on 160K orginal miles. Last week, I went to start it up and it will turn over but not start. Now I'm a junior mechanic and I instantly thought fuel pump. Fuel pump is good. I'm getting a healthy gyser of fuel at the engine. I next thought spark. I took a plug out and did the screwdriver test and I have good spark. I shot starter fluid into the intake and it will not start. I visualy checked the fuses.... they looked good. There is no check engine light and the computer is offering no codes. What else could cause it all of a sudden to have these conditions? Any guidance would be appreciated!!
Wes
well what kind of spark, where is spark, is it at right time and in all cylinders? What screwdriver, put the plug against the block... I once had car die on me while driving, plenty spark at coil and nothing at plugs, the distributor rotor had shorted inside to the shaft.
I know of cases where GM "small cap" HEI ignition systems will burn throughout the cap internally and you will get a spark but NOT a strong one as it is pertly "leaking" through the burn tracts inside the cap
and for the fuel flow @ the engine I assume you disconnected the line into the central multi point injector thingy - I have heard of plenty of injector unit failure causing NO start / ZERO fuel into engine
also check the Fuel PRESSURE over flow as it being a return type of system if the Pressure regulator has quit there will be flow but NO pressure and NO fuel injection
Well, I feel like a bit of a bonehead. It ended up just being a extremely dirty distributor cap & rotor. I didn't suspect because I had just replaced it less than a year ago. What causes the extreme buildup of corrosion on the points so quickly? I did fork a couple extra bucks and got the copper pointed ones.
Wes
