1 - 2 of 2 Posts
So I have an o6 envoy XL Denali and every time I fill my tank full of gas it shows empty and the check engine comes on. But when tank is about half the check engine goes off, keep in mind that I'm not constantly driving, but I really have no idea whats up, not sure if its a gauge cluster problem, maybe a sending unit problem, no idea! any suggestions?
well, the check engine light is weird.
but the gas light- and its erratic operation may be related to sulrfur buildup on the float and its resistor. some people have luck by running several bottles of techron in several tankfuls.
to help remove some of this buildup.
in this pic (mustang sending unit), note the float- and where its attached to.
depending on the amount of gas in the car- the slider moves across the resistor. The variable resistor- gets buildup of sulfur- and you get the erratic fuel gauge.
1 - 2 of 2 Posts
