04 Chevy Aveo Heater Core Removal?
1 reading
22K views 8 replies 5 participants last post by  boston boy
#1 ·
The heater core started leaking recently in my gf's aveo and she was able to pick up a replacement heater core. So I get the fun task of swapping units.
First off how do I begin pulling panels? Screws aren't very visible and some parts seem to pop off with clips, but there is very limited access.
What all will I need to pull to reach the heater core? The casing which houses the heater core is visible but very tucked away and I honestly don't know how I'm going to get it out.
Any tips pointers or advice is extremely appreciated!
Thanks.
#4 ·
good luck. thats all i can say. really nice thing is, is the hidden screws in the dash. you can barely get to them, and im sure most people probably just pry the dash out anyways. rather than facing forward like all the others, these actaully come in from behind on an angle, and are located by the a pillars, by the firewall, but inside the dash. another fine design by the fine people of GM. kind of like the rest of that car.
#6 · (Edited)
Did you disconnect the heater hoses, remove the refrigerant and disconnect the A/C hoses too? If there is a hose on the A/C drain that will need to come off also. I have never worked on an Aveo but there may be some fasteners under the hood.
