Folks,
Ive got an '02 Bonneville that is leaking water - it has a sunroof and Ive finally found the source (I think).
Basically after a rain storm (not a car wash) a puddle of water collects in the rear driver side passenger footwell area.
I can see a line of water today coming from the 'B' pillar (the drivers seat is bolted to the floor right there and the carpet underneath it is wet).
Looking at the door seals they are pretty dry so I dont think it is coming from there.
there are 2 suspects:
1. the is a line of trim that runs across the roof
2. the sunroof drain plugs
Can someone verify if the sun roof drain plugs run down the B pillar to the ground - or maybe has some other way that water could drain out of the B pillar under the carpet into the rear footwell?
The head liner is dry
The plastic covering the B pillar appears dry(no squishy sound if you press on it).
